DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Remove Glue??
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Author Message
Nightfox
from United Kingdom
PostPosted: Thu Oct 16, 2008 12:09 pm Reply with quote
We bought this stupid thing off ebay that keeps insects out your windows, but it required to be stuck around the inner frame, it was velcro strips and you put fabric mesh over it to keep insects out, anyways, it was rubbish so we ended up taking it down, but in order to keep it up, it kept falling down u see, I had the brainwave of using superglue, then the velcro strips wouldnt come off so had to be yanked down, but its taken some of the velcro strip backing with it and left it on the window and I cant for the life of me get it off, is there a good way to remove superglue from PVC window frame?
I scrubbed it, scraped it nothing works and It looks a mess I dont wanna make it worse.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 24 times
PostPosted: Thu Oct 16, 2008 5:21 pm Reply with quote
super glue remover?
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 2 times
PostPosted: Thu Oct 16, 2008 6:30 pm Reply with quote
Oh dear, bit of a problem, the super glue has probably "reacted" with the uPVC, I would hazard a guess that this will be irreparable.
Back to top
 Alert Moderators
TonyWarrington
from United Kingdom
PostPosted: Thu Oct 16, 2008 7:20 pm Reply with quote
I agree that the glue could have reacted with the uPVC. The only thing that I have used that worked is Acetone. I think that super glue remover is based on acetone product.
Caution Acetone or even super glue remover on UPVC could cause greater damage as it may react with PVC products and cause swelling.
Back to top
 Alert Moderators
Nightfox
from United Kingdom
PostPosted: Thu Oct 16, 2008 7:57 pm Reply with quote
what about painting over it, i have some pvc primer but this isnt thick enough, what could go on top to cover the mess?
Back to top
 Alert Moderators
wotan
from United Kingdom
Thanked: 138 times
PostPosted: Fri Oct 17, 2008 2:44 am Reply with quote
Buy a new window.
Back to top
 Alert Moderators
Nightfox
from United Kingdom
PostPosted: Fri Oct 17, 2008 11:03 am Reply with quote
Can you apply Weathershield External Gloss on top of PVC primer? to make the marks un noticeable?
Back to top
 Alert Moderators
Nightfox
from United Kingdom
PostPosted: Fri Oct 17, 2008 3:29 pm Reply with quote
Or even normal white gloss? or would it look stupid, Ive read exterior gloss isnt as shiny, so works well on PVC thats been undercoated with primer
Back to top
 Alert Moderators
TonyWarrington
from United Kingdom
PostPosted: Fri Oct 17, 2008 4:09 pm Reply with quote
Nightfox, sorry but I have no idea if your painting ideas would work. I think you may get more feedback if you post again about painting over in the Painting and decorating section
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 2 times
PostPosted: Sun Oct 19, 2008 4:43 pm Reply with quote
I doubt it would look good at all, I think you are a bit stuffed TBH.
Back to top
 Alert Moderators
Bilioustrumpstaine
from United Kingdom
Thanked: 3 times
PostPosted: Sun Oct 19, 2008 5:56 pm Reply with quote
Caution. Your cure could/will end up looking worse than the original problem.
Can you fit some upvc trim to cover the damaged areas ?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
how to remove glue 2 4700 Sun May 27, 2007 11:47 pm
Spilt super glue on lense 7 1360 Sat Dec 10, 2005 5:35 pm
Getting glue off wood floor boards 5 860 Sun Nov 20, 2005 7:39 pm
Super glue??????? 10 1460 Wed Jan 25, 2006 6:46 pm
gorilla glue 5 5340 Fri Aug 19, 2005 1:03 am
DIYnot
