right type of silcone
10 Jan 2007
changing some misted up glass units no more than 300 mm sq, is it possible wrong silcone could have been used in the first place, if so what the correct 1 to use
any help would be appreciated
The correct silicon to use is low mod neutral cure. as if you use high mod or assatoxic cure the assertones can damage the perimeter seal to a double glazed unit.
Not 100% sure but don't think so , I believe that 335 is a reactive cure.
Like he wrote above.
You need to ask the shop for low-modulus because the acetone in the high-modulus stuff will attack the sealing system on your glazing unit. Low modulus takes a long time to go off though.
