Just a problem I've got at the minute. The lighting circuit in the front room is 2 way, both ends are a standard light switch. I've replaced one end with a dimmer switch (blue, yellow and red cables), and put in a new 2 way light switch the other end (lots of cables this end, the blue, yellow and red from the other switch, and also another red, a brown, and a blue and black in a choc block).
So I've installed both switches, but the fitting can only be switched from one end and not turned off/dimmed from the other. Am I missing something here?
