What is it I need?
19 Dec 2007
Warwickshire
Hi.
I need to find two metal thingies to hold a bit of 4x2 or similar to secure my garage doors internally. Ive no idea what you would call what I need and I have looked at the diy stores without success.
They cold be metal rectangles to slide the wooden bar into or u shapes to hold the wooden bar to stop the door being forced from the outside.
Im sure someone out there will have the answer!
Cheers
tz - up & over doors - consider, as an alternative to what the 7th Cavalry used to use when securing the gates to their forts, :LOL: a couple of tower bolts fixed low level on the doors. Steel doors - used nut/bolts or pop-rivets to fix. Much more convenient to lock/unlock than weilding a 7' length of timber
Try a local blacksmith. (yellow pages)
A local engineering firm.
Your local garage (ask if the do any welding)
