Hi folks,
I'm really hoping someone can help me out...
We've got a Baxi Combi Instant 105e and at the moment are struggling for hot water in the Kitchen...
If I run the tap in there (even at a really high flow), the boiler doesn't notice and start to heat the water. If we use the pre-heat setting, I get warm water until that's exhausted, and then it runs cold - the boiler doesn't kick-in at full tilt. The only option to get more warm water is to turn pre-heat of and on again, to obtain another few litres...
Interestingly though, if I run the taps in the bathroom, the boiler does take note and begin to heat the water. It seems that I need to hit a pretty high flow-rate before anything happens though - certainly higher than the 2.5L/min that the user manual suggests...
Is the flow-sensor adjustable at all, or user-replaceable if the consensus is that it's shot?
Thanks in advance!
Rob
Thanks in advance!
Rob
