Leaking stop tap
19 Oct 2008
Staffordshire
Hi all
I have a standard 15mm to 15mm stop cock under my sink which looks fine until i close it off. When closed the taps in the house are cut off fine but the stop cock starts to leak around the gland, is this just the gland nut packing because i'm not sure with it being fine in it's open position. must be leaking when i turn it off to go on holiday but must only leak for a while because there's no flooded kitchen when i get back :D i was thinking of trying to tighten the nut or ptfe around spindle or just buy another tap and swap the head gear.
Any advice much appreciated cheers !
Before replacing the head gear you should go ahead and pack the gland. If it works you're laughing, if it doesn't it's cost you about 5p worth of ptfe.
yeah cheers for that, going take a look next friday when i'm off, i'd had a look around on the net but couldn't see anything where someone had a tap leaking on when it was closed
Thanks Again
Stop tap leaking in it's off position is most likely the packing gland. No need to wait till friday, it's a two minute job.
You'll need a shifter or appropriate sized spanner, ptfe tape and a small flat screwdriver (for packing down the ptfe)
There's no need to knock the water off at the street. Undo the gland nut counter clockwise, rake out any old packing material with the screw driver. Wind ptfe around the spindle and pack it down.
Tighten the nut back up and away you go.
:D not in position to do it at minute she has washer and dishwasher on at minute so coudn't turn off to test no rush but thanks a lot for the advice
19mm & 15mm spanners sorted it out, nipped it up and it's ok, feels a bit better as a tap now aswell. Will keep an eye on it but looks ok for now, thanks to anyone who replied, can't believe how quick the responses come in just trying figure out how to delete a post now as i only registered today and posted twice by mistake.
Thanks again folks
