DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Wall Scanner Cable / Metal / Wood Detector
Post new topic   Reply to topic    DIYnot.com Forum Index > Tools and Materials
Author Message
Bammer
from United Kingdom
PostPosted: Mon Oct 20, 2008 11:04 pm Reply with quote
Anybody got any ideas as to what Wall Scanner Cable / Metal / Wood Detector I should buy having a budget of about £60uk. I have seen the Bosch DMF 10 Zoom Wall Scanner Cable / Metal / Wood Detector but not too sure. Have a pot rack and magnetic knife rack to hang in the sculery-lol-so any help appreciated as to what is best to buy. The items will be hung on a gable end of a kit house (bungalow) which is not a traditional build but kit...so p/board and breeze wi harlin on the exterior
Thanks in advance
Back to top
 Alert Moderators
xerxes
from United Kingdom
PostPosted: Tue Oct 21, 2008 6:32 am Reply with quote
This topic has been much discussed in DIYnot, as a search will reveal.
A number of people recommend the Bosch DMF10; I have an earlier Bosch detector which works well. However, I'm baffled when I read a claim that a detector can find a timber stud: surely it's the metal fixings in the stud that they find? Perhaps someone can enlighten me.
That said, if you're just trying to find studs I'd use the traditional method of tapping for differences in sound, probing with an awl, perhaps drilling trial holes if you need to. The studs should be equidistant, so once you've found one the rest aren't difficult to locate.
If you're checking for cables or pipes under the surface, then a detector is a good thing to have, along with looking at where the electrical accessories etc. are fitted.
Plasterboard and breeze block construction means you can drill anywhere (anywhere you're not going to drill through a cable) and use suitable fixings.
Back to top
 Alert Moderators
FDJ
from United Kingdom
Thanked: 7 times
PostPosted: Tue Oct 21, 2008 1:58 pm Reply with quote
Bammer wrote:
I have the Bosch DMF 10.
It seems to be totally incapable of detecting wooden studs behind plasterboard.
What it can do however, is detect the nails and hence find the studs that way.
It is also quite sensitive in detecting cables in walls so it is not completely useless.
Frank
Back to top
 Alert Moderators
Bammer
from United Kingdom
PostPosted: Wed Oct 22, 2008 12:09 am Reply with quote
Many thanks for the replies and the information. The sockets are just above the worktop and look to be feed in a loop. The only exception being the extractor isolator above the hood which should have been taken vertically from the cooker supply. So very little likelihood that cables on the wall that being drilled. Think I will go with the old traditional method as suggested as give the wall a few taps to located the studs and then measure out.
Again, thanks
Back to top
 Alert Moderators
Fangorn
from United Kingdom
PostPosted: Thu Oct 23, 2008 8:48 am Reply with quote
Hi have a look at this one from Zircon
http://www.toolbank.com/p/C4007/ZIRZ62116
CenterVision technology finds the centre of studs and joists in a single pass so this takes the guess work out of where the center of the stud is. It also detects metal and power Nice piece of kit!
Back to top
 Alert Moderators
Mark Br
from United Kingdom
Thanked: 109 times
PostPosted: Thu Oct 23, 2008 2:50 pm Reply with quote
It does indeed look good. Have you (or anyone else) tried the Zircon. I need to replace my detector and would be interested if it does "what it says on the tin"
Back to top
 Alert Moderators
Bilioustrumpstaine
from United Kingdom
Thanked: 3 times
PostPosted: Thu Oct 23, 2008 3:22 pm Reply with quote
I have ordered one today, the metalliscanner m40, from York tools.
I will report back over the weekend as it is promised for tomorrow.
Back to top
 Alert Moderators
Mark Br
from United Kingdom
Thanked: 109 times
PostPosted: Thu Oct 23, 2008 5:30 pm Reply with quote
Cheers - I hope it turns out to be as good as promised.
Back to top
 Alert Moderators
Bilioustrumpstaine
from United Kingdom
Thanked: 3 times
PostPosted: Fri Oct 24, 2008 2:20 pm Reply with quote
It's here !
I have given it a road test on my walls at home and it seems to be doing the business.
This is a metal detector only and identifies studs by picking up on the nail heads.
Back to top
 Alert Moderators
Bammer
from United Kingdom
PostPosted: Mon Oct 27, 2008 1:40 am Reply with quote
Bilioustrumpstaine
That's great. Thanks for the update and might well consider this from Santa as I have a few jobs from ma lady-lol.
Regards
Back to top
 Alert Moderators
Bilioustrumpstaine
from United Kingdom
Thanked: 3 times
PostPosted: Mon Oct 27, 2008 1:45 pm Reply with quote
I have been working in some offices where there doesn't seem to be any logic to where the pipes and cables run and this bit of kit performed really well. It cost me just over £60 but well worth it.
I got it here
http://www.yorksurvey.co.uk/tools/zircon/2099/zircon-metalliscanner-m40-metalfinder.html
More info here
http://www.zircon.com/products/metal_m40.html
Back to top
 Alert Moderators
Mark Br
from United Kingdom
Thanked: 109 times
PostPosted: Mon Oct 27, 2008 2:45 pm Reply with quote
Good to hear it's as good as advertised. I'm putting in an order for the i520.
Back to top
 Alert Moderators
neds
from United Kingdom
Thanked: 27 times
PostPosted: Mon Oct 27, 2008 6:40 pm Reply with quote
I bought the DMF 10 as it was going cheap on the bay. Does the job, detects studs OK, a little over sensitive to live wires though, could be a good thing though! icon_lol.gif
Back to top
 Alert Moderators
DrEvil
from United Kingdom
PostPosted: Wed Apr 13, 2011 9:21 am Reply with quote
Does anyone have any opinion after using the Zircon i520, or indeed the i700?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Tools and Materials All times are GMT
Page 1 of 1
Jump to:
Best cable detector available 8 900 Wed Oct 13, 2010 9:08 am
Running cable through a partition wall 4 680 Fri Sep 18, 2009 5:50 pm
Cable and pipe location devices 2 720 Tue Aug 22, 2006 12:45 pm
Cable Staple gun 3 440 Fri Nov 17, 2006 10:58 pm
Cable Avoidance Tool or CAT for short! 6 880 Sat Aug 16, 2008 7:06 pm
DIYnot
