CONCRETE ROOF
22 Oct 2008
Lancashire
i would wanna replace my outshed concrete roof which has cracks with joist and like a flat roof. the outshed is joined with the house and the concrete roof is embedded into the wall of the house. i think the roof is at the same level of the ceiling in the house which is in line with the floor of the upstairs rooms if u know what i mean.
how will it be possible to replace this without affecting the walls of the outshed as i would like to turn it into a nice pad
thanks for ur help
start at the far end (away from the wall) and jack hammer it to pieces.
the re-bar should prevent you from falling through. :eek:
once you get closer to the wall, channel it out piecemeal from one end and replace the bricks as you go.
there may unavoidable damage as the concrete could be quite tight between courses.
how wide is the roof?
its like 14ft by 22ft approx.
as to covering it with lead, the walls ( 3-4 line of bricks towards the ceiling needs replacing on all the 3 walls of the outshed)
secondly, i want to take out the middle wall to make it a single space, it is for this reason i think the 3 walls will be taking on too much weight and could collapse starting from the middle.
do i make any sense to u guys
