My boiler has just started to play up the the problem is that the burner lights up ok runs for 5-10 mins then stops, and will not re-light up for anything from 15-30mins although the spark electrode is sparking away.
I have checked the hi, lo, and overheat thermostats and all ok. The pump is running ok. I have checked the voltage across the main gas solenoid whilst the boiler is running and getting 240volts until whatever the problem is causes the voltage to drop to zero & turn the gas off. A friend said it will be the thermocouple but there is not one fitted on this boiler, unless it is done through the spark electrode/flame sensor. Help please
