Not 100% sure if this will be the same for it, but normally on rear lights you remove the actual light cluster from inside the boot. Have a look on the boot trim where the lights are, there should be a clip or similar to remove an area of trim to allow access. Then the plastic light clutser containing all the bulbs will be wither cliped or screwed in place. Undo this and replace the appropriate bulb.
HTH
Dave
