No feed from header tank
21 Oct 2004
I have problem clearing blockage from header tank to System. Tried bleeding but just lost more water from system. Tried adding sludge chemicals to header but no go. Any suggestions? :cry:
start cutting pipework!
if your lucky try a drain clearing "snake" might do the trick
you have problems with your system
i would advise getting someone to take a peek
it wiil occur again :D
Yep, you have a blocked cold feed. Elementary plumbing stuff. Always worth prodding it as per Kevs advice.
Usually though its a pipe cutting job near the h connection, because its blocked solid. Especially if we get called out to it on a weekend........
Simon
www.hwch.co.uk
