I have a 25 year old Ideal Standard conventional boiler and recently the pump went. I replaced the pump with a GRUNFOS 15/60 pump and the new pump appears to be working fine.
However, the pipes into/outof the boiler, all radiators and also hot water are never more than lukewarm even when the room thermostat and the boiler hot water thermostat are put at very high (max) settings.
The boiler turns itself off/on frequently even with the boiler stat on max. value with the result that the water pipes never get really hot.
Could the problem be due to air in the pipes or to a defective boiler stat? How could I tell?
