radiator thermostat for potterton flamingo 2 boiler
D
Deleted 102983
I have a potterton flamingo 2 boiler (which has it's usual boiler thermostat) but I need some advice on where a wall thermostat would need to be fitted? This is a thermostat to regulate the temperature in the house. At the moment I only have thermostats on the individual radiators, but I want one that controls by the temperature in the house.
Would this type of thermostat be fitted to the water/central heating timer or would it be fitted with the boiler?
Hope someone can help.
Thanks.
it is wired to the programmer (timer), and the thermostat is placed in the living room that is mostly occupied. it should not be close to a source of heat or cold such as boiler, cooker, sunny window or radiator, nor in a draught, so that it picks up the true room temperature.
the radiator in the room with a wall stat should not have a thermostatic valve fitted (otherwise it will be in contention with the wall stat) but can be adjusted with the screw-down valve at the other end so it heats up more slowly than all the other rooms.
if you look up the make and model of the programmer/timer you can get a manufacturer's wiring diagram that shows how to do the connection.
however if you are not familiar with safely doing mains-voltasge wiring I suggest you get a heating engineer or qualified electrician to fit it for you.
Thanks, that's helpful. I'll track down the manual for my timer and find someone to fit the thermostat.
