ariston microgenus lockout
5 Jul 2007
Hull
hi im having a problem with my ariston microgenus mffi23 combi boiler, lockout led comes on regularly and boiler resets when i press reset button. was advised to change thermistor, is this the DHW temperature sensor? where could i get one please
Which LED?
There's 2 red ones. One igniton one pump related.
Or an orange one related to the APS.
it is in manual as ignition failure lockout red l.e.d. The boiler will not reset if the temperature l.e.d's [yellow] are lit but if i run some hot water i can reset? p.s this problem has started since i emptied system to clean it.
From your description i havent got a clue. Temp and thermistors should have nothing to do with ignition. Although it would probably be more clear when in front of the thing.
Can only suggest getting a competent boiler engineer out.
thanks anyway, had similar prob last year and had about 4 different engineers to it, had british gas sort it, new secondary exchanger and dhw probes. Only about 8 years old but maybe should think about replacing it.
