DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
grout removal
This topic originated from the How to page called Grouting
Click here to return to the page called Grouting.
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
kayfrank3
from United States of America
Thanked: 0 times
PostPosted: Tue Dec 31, 2002 3:12 pm    Post Subject:
grout removal
Reply with quote Thanks
I need to remove excess grout on the surface of a ceramic tile counter. There is dried grout all over the new tile countertop. It has dried and I can't get it off with soap, water, and a nylon scouring pad. Help
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Guest
Thanked: 0 times
PostPosted: Tue Dec 31, 2002 3:30 pm    Post Subject:
Re: grout removal
best way to get it off is a sharp blade and scrape it,stanley make a holder for their blades so its like a proper scraper but with a very sharp edge,the blade just pushes in,you can get one from any diy store or hardware shop...
Back to top
 Alert Moderators
kayfrank3
Thanked: 0 times
PostPosted: Tue Dec 31, 2002 3:55 pm    Post Subject:
Re: grout removal
Will the blade hurt, or scratch, the tiles?
Back to top
 Alert Moderators
Guest
Thanked: 0 times
PostPosted: Tue Dec 31, 2002 5:08 pm    Post Subject:
Re: grout removal
no not if you use a new blade...
Back to top
 Alert Moderators
Quadroclops
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 01, 2004 8:12 am    Post Subject:
...in case this helps anyone else whose excess grout hasn't completely cured yet (could be weeks after the job was done) -a couple of hours soak with a sugar solution softens the grout. Large bits should then be removed with a sharpened block of hardwood, & then scrub the rest with a nylon scouring pad -the kind for dishwashing- & plenty of water
____________________________
moderator
locked to prevent hi jacking
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
How do i clean grout off my glass blocks and tiles 4 1320 Fri Dec 10, 2004 2:53 pm
Cleaning off old sealand and grout 2 500 Mon Sep 22, 2008 7:00 pm
Shower wall tile grout cracking/leaking 3 1480 Wed Jun 11, 2003 8:37 pm
Browny/yellow stains on grout 5 1080 Tue Jul 27, 2004 10:25 pm
dirty tile grout 2 980 Sun Sep 25, 2005 7:10 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
