DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Inspection/foul drain cover
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
iddon
from United Kingdom
Thanked: 1 time
PostPosted: Fri Nov 07, 2008 4:14 pm Reply with quote
I have 2 inspection covers within 1 metre of each other and I have plans to extend out with an extension which will go over inspection cover and leave the remaining cover outside. I had previously assumed that it was necessary to re-route the whole drain so that it remain outside of the extension, however, I'm being told by various builders that it is simply a case of sealing blocking the inspection cover that will fall inside the planned extension and simply continue to use the remaining cover for the rodding point. This being the case can anyone advise on sealing the cover that will fall into the interior?
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1291 times
PostPosted: Fri Nov 07, 2008 7:05 pm Reply with quote
it may be that you could do away with one of the i.c.'s altogether, this may be unlikely, but worth investigating.
if it is the case that both i.c.'s remain, then the chamber that falls within the extension can be 'sealed' but must still remain serviceable. this involves fitting a screw down double seal lid to the chamber.
"sealing and blocking" is not acceptable.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Fri Nov 07, 2008 8:30 pm Reply with quote
my sis in law had this done in extension, guess what happens when drain gets blocked and the stuff builds pressure. yes the lid gives way.
Back to top
 Alert Moderators
PJ1
from United Kingdom
PostPosted: Fri Nov 07, 2008 10:17 pm Reply with quote
noseal is spot on!
You need to investigate the drains within the i.c's, you may find one is foul, the other surface water. Just run water to test, from sinks, toilets and gullies and see what goes where. If it's all one drain you may be able to divert the drains from the i.c. to be covered, into the other one. But you have to ask, why wasn't that done in the first place?!!
If they're two separate drains you won't be able to do that, but may still be able to relocate the offending i.c.
Make sure you leave access to the drains whatever. Once covered, they're sure to block and you'll be knackered!
You'll need Building Regulations approval for your extension, so speak to Building Control at your Council office (usually a helpful bunch).
Double seal bolt down covers won't leak if fitted properly, but it's a brave man that takes the lid off when the i.c. below is bursting with you-know-what!
Back to top
 Alert Moderators
iddon
from United Kingdom
Thanked: 1 time
PostPosted: Sat Nov 08, 2008 10:41 am Reply with quote
thanks for the guidance
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Foul drain inspection cover 4 560 Wed Aug 06, 2008 1:45 pm
Drain/sewer design - connect foul to rain branch? 9 240 Sat May 18, 2013 7:57 pm
Foul water drain through footings 8 500 Tue May 14, 2013 7:55 am
Question on foul drain / adding storm water drains 23 380 Sun Mar 31, 2013 5:33 pm
Foul water drain leakage 2 160 Mon Sep 08, 2014 4:05 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
