DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Down lights/Spotlights
This topic originated from the How to page called Types of lighting
Click here to return to the page called Types of lighting.
  View previous topic :: View next topic
Author Message
Speedy
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 26, 2004 12:17 am    Post Subject:
Reply with quote Thanks
Hi
I am going to fit 12 down lights 230v 50W bulbs, to my ceiling.
I\\\'m hoping i can connect them to my room ceiling light/connection.
should i use 1 12 point connection/junction box or split them into 3\\\'s ?
And what cable should i use, please.
Thank You
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Oct 26, 2004 7:17 am    Post Subject:
Re: Down lights/Spotlights
No such animal, and you'll struggle to get lots of cables into a normal JB.
Best plan would probably be based on what makes the most sense from a physical POV, i.e. where the lights are in relation to each other, to the existing rose and to the joists, but at all times seeking to minimise the use of JBs - i.e. daisy chain from one light to the next as much as possible.
Same as the existing lighting circuit - 1.0mm˛ or 1.5mm˛ twin & earth.
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Tue Oct 26, 2004 9:59 pm    Post Subject:
I think Speedy's talking about one of those CH joint boxes where a 12 way block has been mounted in a double pattress with a BP on top.
Back to top
 Alert Moderators
Speedy
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 27, 2004 12:13 am    Post Subject:
I will daisy chain them, i think that will be the easy way to do it for the space Ive got to work in is plenty.
Thing is, i wasn't sure if daisy chaining them was safe enough.
Maybe if i daisy chain 6, then another 6.
Just one thing about the cable, i got 1.00mm cable, but not twin n earth.
I may be sounding stupid with the next comment/question but the lights Ive got only have twin cable, brown n blue. if i use twin n earth do i connect the earth to the metal of the new light fitting.
Hope that makes sense ?
I'm going to look on this site for a Pro to check everything once i done it, will most sparkys be ok at doing this or would it be to small of a job for them ?
Regards
Speedy
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Wed Oct 27, 2004 1:30 am    Post Subject:
Why on earth not?
Are you sure that's cable you've got, and not flex??
Not if they are double insulated fittings. If they don't have earth terminals then don't try to earth them, just keep the earth continuity going with pieces of choc-block.
__________________
Back to top
 Alert Moderators
Speedy
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 28, 2004 12:02 am    Post Subject:
Your right, it is flex and not cable. is that ok ?
The rating of it is 10A 2400W
I see a re-visit to the electric shop ?
Thanks for you help.
Back to top
 Alert Moderators
JDLDIY
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 28, 2004 12:39 pm    Post Subject:
Should use cable, if anyone managed to do some damage in the future by hanging xmas decs or something, at least there is the protection of the earth core.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
spotlights and flourescent lights 5 340 Tue Feb 22, 2005 4:46 pm
Replacing single light with low voltage spotlights. Request. 3 920 Wed Aug 23, 2006 5:33 pm
LED spotlights 15 700 Sat Jul 29, 2006 11:07 pm
Spotlights leaving black marks on ceiling 20 960 Thu Sep 14, 2006 3:31 pm
Mains Halogen Spotlights 2 280 Thu Sep 21, 2006 7:30 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
