Hi all,
just a quickie (hopefully).......can anyone plse confirm what size pipe should run to the boiler for the gas and water?
I think the actuall connections at the boiller are 15mm, the connection from the main water supply will run from a 22mm pipe which is within 2metres of the boiler anyway, should a 22mm be run from this up to the boiler where if will change to 15mm or is it ok to run a 15mm pipe straight of the main water pipe to the boiler?
Again with the gas supply to the boiler is it ok to run a straight 15mm supply from the main gas supply to the boiler, the boiler is very close to the gas supply anyway so not sure if the a 15mm or 22mm pipe will make much difference?
Any help is appreciated!
Cheers
John
PS
If it makes any difference its a 3 bed with a shower and no bath.
Cheers
John
PS
