When i switch on my HC60NG relay box, if the room temp is set at 21 degrees, and the actual temp is the same or above, the relay switch will go off! however if i was to increase the temp to more then actual room temp it will stay on till it reaches the temp and then go off, it will not start again if the temperture decreases. ( which it should do), any help on this issue will be great.
