Do you mean because its a full tin ? Best use two tins and pour half into the empty one while you thin the main one. Then pour the first into the second and give a good stir. Pour them back and too into each other several times. Obviously you will have too much paint to fill one tin but i would assume you are going to then pour into a pant tray or scuttle.
hi there i mean what do you use to thin the emulsion?? just water how mutch would i use?? i am putting emulsion on and its just cracking and blistering.i am using dulex matt emultion,sum 1 said to use crown as it has a oil base in.
