DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Custom Cable Lighting
This topic originated from the How to page called Types of lighting
Click here to return to the page called Types of lighting.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
Guest
Thanked: 0 times
PostPosted: Thu Jan 02, 2003 10:17 pm    Post Subject:
I am creating a custom cable light system and have a question about what the system will support.
I will be using 20' of 16 ga. insulated wiring, anchored into wooden studs at one end and plugged into a 110v standard outlet at the other end. The wiring will be attached to insulators and drawn taught.
My question is, using 120v/50w halogen bulbs and no transformer, how do I figure out how many bulbs can be placed in this circuit before I overload it? Or how many amps will support how many of these bulbs? Thank you
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Guest
Thanked: 0 times
PostPosted: Thu Jan 02, 2003 10:34 pm    Post Subject:
Re: Custom Cable Lighting
hello, as you will be using 16ga wire it is hard to give you an answer, as over here in the uk our cable is metric and is measured in mm.
May i suggest
http://www.handymanwire.com/ubbthreads/postlist.php?Cat=&Board=UBB2
Which is an american equivilant of this site, they will be able to give you an exact answer, incidentaly each lamp will draw aproximately 2.4 amps
Back to top
 Alert Moderators
cjgarlick
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jan 04, 2003 2:54 pm    Post Subject:
Reply with quote Thanks
Hello
As per the previous posting, it's all a question of current draw.
The formula you need is I=VA (Watts = Volts x Amps). This converts to A=I/V (Amps = Watts divided by Volts). Therefore (sorry to contradict previous post) each 50W lamp will draw 50/120 = 0.42 Amps.
Here in the UK a domestic lighting circuit would be fused at 6Amps, so you could have 14 lamps. Are you dedicating an entire consumer unit (fusebox) circuit to this lighting system, or is it part of an existing circuit? If it's an entire circuit in its own right, check the regulatory fuse rating for a domestic lighting circuit in your area, and that's what you have got to play with. If it's part of an existing circuit (much more likely I guess), you need to do some sums based on pragmatics - work out what drain the other lights are already putting on this circuit, and see what you're got left. Don't load the whole thing up to 100% of fused circuit capacity though, for obvious reasons - try to work to eg. 75%.
HTH - Kind Regards
__________
CJG, U.K
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
TV Aerial Cable 5 960 Thu May 13, 2004 9:22 pm
earthing + low voltage cable 4 740 Thu Jun 26, 2003 9:33 pm
Cable Trays - a novel idea but where can I buy it ?? 6 420 Sun Apr 06, 2008 1:47 pm
Satellite Cable 3 220 Sun Apr 05, 2009 2:38 pm
cable size oven 4 1040 Thu Sep 18, 2003 3:46 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
