gas to coal fire?
17 Jan 2006
Derbyshire
Im looking at changing my gas fire back to a coal/log fire. Ive read about a lining being needed for one or the other but not sure which. With it originally being a coal fire then being changed to a gas fire would i need to have the lining removed or would it be fine to just put in a new hearth and use coal/wood (after having it swept) or is there more to it? The house was built around 1990 if it makes a difference.
A lining is not needed for either. If you have a gas tight chimney you can vent a gas fire through it, or indeed a solid fuel fire.
Your first step is to determine what you actually have got by removing the fire (need to be corgi) or looking at the chimney ie. is there a metal terminal on top?
If no liner and no terminal then do a smoke test (or get corgi engineer to do it for you) and test for smoke coming out in other rooms of the house, stack in roof, or badly pointed joints in stack on roof (unlikely as 1990's).
Get a sweep in to confirm everything is good to go and get yourself whatever solid fuel fire you desire.
is there a stainless steel flexible liner in the flue at present?
Couldnt tell you, the fire in place now covers everything up.
No problem with needing a corgi for the gas fire, its not connected to the gas mains because of a leak that we could smell but the detector couldnt find. Im not too sure on what is on the top of the chimney, i will have to check, next doors top is different to ours but i think they too have gas.If its a metal top would it need changing to a open top chimney pot? It would be nice to have a log fire burning for christmas day.
if there is a s.s. liner you will need to remove it and the cowl.
you can then fit a suitable clay pot to the existing chimney. a standard cannon usually does the trick.
