DIYnot
Local | Network
   DIYnot > Forums
Local | Network
8.5 kw shower cable size
Goto page 1, 2, 3  Next
Author Message
scottg
from United Kingdom
PostPosted: Sat Nov 15, 2008 9:19 am Reply with quote
can i fitt 8.5 kw shower using 6 mm2 cable 3m from mains board
only thing is its going through loft insulation more than 100mm
would it be ok to use trunking with insulation on top would this effect cable calculations
Back to top
 Alert Moderators
TopTrumper
from United Kingdom
Thanked: 1 time
PostPosted: Sat Nov 15, 2008 9:30 am Reply with quote
A whole 3 metres?
yes 6mm will be fine
Back to top
 Alert Moderators
GaryMo
from United Kingdom
Thanked: 163 times
PostPosted: Sat Nov 15, 2008 10:26 am Reply with quote
6mm through loft insulation greater than 100mm is rated at 27A (method 101#).
Your 8.5kW shower is rated at (8500/230) 36.96A.
The current carrying capacity of the cable in its installed conditions must be at least the rating of the device it's supplying.
Can you reroute the cable away from the insulation? Clipped direct (method C) with no insulation is rated at 47A.
Back to top
 Alert Moderators
GaryMo
from United Kingdom
Thanked: 163 times
PostPosted: Sat Nov 15, 2008 10:27 am Reply with quote
TopTrumper wrote:
A whole 3 metres?
How did you come to that conclusion?
Back to top
 Alert Moderators
TopTrumper
from United Kingdom
Thanked: 1 time
PostPosted: Sat Nov 15, 2008 8:01 pm Reply with quote
GaryMo wrote:
TopTrumper wrote:
A whole 3 metres?
EASY
PS, im sure the OP understood every word you just said.
Are you seriously trying to say 6mm cable for a 3 metre run is not suitable?
Back to top
 Alert Moderators
GaryMo
from United Kingdom
Thanked: 163 times
PostPosted: Sat Nov 15, 2008 8:06 pm Reply with quote
Maybe it's you who didn't understand anything I said?
Easy as in you guessed without looking at table 4D5?
Are you seriously trying to tell me that a 6mm cable with a rating of 27A, given its installation method is good for a design current of 36.96A?
I sincerely hope not!
Back to top
 Alert Moderators
TopTrumper
from United Kingdom
Thanked: 1 time
PostPosted: Sat Nov 15, 2008 8:46 pm Reply with quote
GaryMo, fair enough, point taken.
Answer me one question, if the OP had said he wanted to install this shower, what cable would you advise him for the 3 metre run?
http://www.alertelectrical.com/Electric-Power-And-Mixer-Showers/Mira-Showers/Mira-Electric-Showers/Mira-Vie-108kw-Electric-Shower-Satin-Chrome-D62127.asp
Back to top
 Alert Moderators
GaryMo
from United Kingdom
Thanked: 163 times
PostPosted: Sat Nov 15, 2008 9:02 pm Reply with quote
I would advise 10mm and keep the cable away from thermal insulation.
Another example of why electric cables and thermal insulation don't mix.
Back to top
 Alert Moderators
TopTrumper
from United Kingdom
Thanked: 1 time
PostPosted: Sat Nov 15, 2008 9:07 pm Reply with quote
Never mind what you would advise him to do,he has already stated
"It is going through loft insulation"
So what cable would you say in your expert opinion, does the OP need for this 3 metre run?
Back to top
 Alert Moderators
TopTrumper
from United Kingdom
Thanked: 1 time
PostPosted: Sat Nov 15, 2008 9:13 pm Reply with quote
GaryMo, to help you along a little, here is the instruction manual for the said shower.
http://www.mira-showers.co.uk/onlinecatalog/pdf/p1088848_w2.pdf
I would like you to take particular notice to page 9, to help, I will quote you a paragraph,
The terminal block will not accept cable larger than 10 mm2.
So as we are looking at tables, what do you say?
Back to top
 Alert Moderators
GaryMo
from United Kingdom
Thanked: 163 times
PostPosted: Sat Nov 15, 2008 9:18 pm Reply with quote
Well, if the terminals won't accept a conductor larger than 10mm then 10mm is the maximum cable size for that given shower.
So, either change the shower, remove the insulation or re-route the cable.
It's not rocket science is it?
Back to top
 Alert Moderators
TopTrumper
from United Kingdom
Thanked: 1 time
PostPosted: Sat Nov 15, 2008 9:29 pm Reply with quote
OK.
Lets assume that the insulation cannot be moved, and there is no other route whatsoever, would you install the 10mm cable?
Back to top
 Alert Moderators
GaryMo
from United Kingdom
Thanked: 163 times
PostPosted: Sat Nov 15, 2008 9:31 pm Reply with quote
I wouldn't install a 10.8kW shower, that's for sure!
10mm in those conditions is rated for a maximum of 36A.
A shower would need to be purchased rated at less than 36A, 8kw maximum.
Back to top
 Alert Moderators
TopTrumper
from United Kingdom
Thanked: 1 time
PostPosted: Sat Nov 15, 2008 9:36 pm Reply with quote
So lets get this right,
if you turned up at a clients house, and they presented you with this shower and there preferred cable route, and the fusebox was 3 metres away, you would tell them your not installing it?
Back to top
 Alert Moderators
GaryMo
from United Kingdom
Thanked: 163 times
PostPosted: Sat Nov 15, 2008 9:48 pm Reply with quote
They would need to take my professional advice.
I would recommend an alternative route thus avoiding insulation. If that's not possible then I would inform them that I could install a 10mm cable but it's only rated at 36A and can only supply a shower rated at a maximum of 8kW.
I would NOT install a shower with a rating higher than the current carrying capacity of a cable.
Why is this so difficult to understand? It's like asking me to put a square peg in a round hole - something has to give.
Back to top
 Alert Moderators
Page 1 of 3
Jump to:
Replacing shower, what size cable is this 18 1280 Tue Jun 30, 2009 1:10 pm
Wrong size shower cable 11 1340 Thu Sep 18, 2008 5:24 pm
8.5 kw shower fuse and cable size 4 1400 Sun Jul 06, 2008 10:23 am
9kw shower.....what size cable?? 4 6020 Thu Jul 03, 2008 3:01 pm
What's the Correct Cable Size for 9.5kW Shower? 2 1620 Fri Aug 25, 2006 6:21 am
DIYnot
