Glow Worm Micron advice
16 Nov 2008
Bedfordshire
hi there, i have a Glow Worm Micron bolier and just today the thing will not fire up..I have checked the fuses and it has power going to the unit and to the water/heating control panel. I have turned the bolier switch to off and waited an hour and then turned the water and heating to on and then turned the boiler switch to on and no joy - the boiler will not fire up.
Any of you guys know why the boiler is not firing up?
Back to top Alert Moderators
Hi Dan - the model is 40FF....and there are no lights/neons alight at all...
i have checked all the fuses in the cupboard where the boiler is and they are all good.. - does the Micron have an internal fuse at all?
cheers, Bailey
It has a 4 amp fuse on the PCB, but fuses seldom go without a cause IMO.
It could be dead fan that blew it, but then again it could be something else - you'll to get a multimeter out and start testing..
