secure lamp holder to lamp stand
Go to a indie electrical wholesale shop and buy the correct size threaded lamp holder
:D
all the lamp holder's I've seen are the same size thread
The most common sizes are 1/2 inch and 10mm, there is a 13mm but not too popular,
can you tell me the name of the adapter I need to fit the lamp holder to the lamp stand, you can see a photo of the lamp holder I'm using in my post
Sounds like you need a 1/2 inch external to 10mm internal reducer and a
10mm nipple about 15mm long all made of plastic which is rare.
However they are made in brass, but as you are using a plastic holder it
would not be earthed.
Only if you have an earth wire present
then I would suggest a brass lampholder, and that would
earth the thread also.
Is the wire 3 core including an earth wire.
http://www.inlico.com/InlicoCatalogue.pdf
Will give you some idea what is available.
Thanks for the prompt reply, the cable has to wires blue and brown,
I could change the cable to a three wire cable and buy a brass lamp holder,
