DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Gas Cooker Removal
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Jim
from United Kingdom
Thanked: 1 time
PostPosted: Thu Nov 20, 2008 9:07 am Reply with quote
I am removing my gas cooker which has the bayonet type flexible connection. As I am replacing with electric cooker is it sufficient to simply disconnect the connector or is some other process necessary please?
Jim
Back to top
 Alert Moderators
JPC
from United Kingdom
Thanked: 20 times
PostPosted: Thu Nov 20, 2008 9:11 am Reply with quote
those bayonet fittings are made for diy...so disconnect it as they are self sealing...
the only thing i would say is, can you be sure its not leaking once disconnected.
Back to top
 Alert Moderators
jameshayes
from United Kingdom
PostPosted: Thu Nov 20, 2008 2:43 pm Reply with quote
bayonet needs to be removed and plugged with a half inch iron plug.
bayonet is a temporary disconnection point only.
corgi or whatever corgi is now called.job.
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Thu Nov 20, 2008 3:20 pm Reply with quote
If your going to quote it needs a corgi.
Why not quote that corgi say its perfectly acceptable to leave a bayonet after disconnecting a cooker
Back to top
 Alert Moderators
kirkgas
from United Kingdom
Thanked: 458 times
PostPosted: Thu Nov 20, 2008 11:58 pm Reply with quote
bayonets are designed to allow people to disconnect and clean behind cooker etc, with the appliance going back in again, it is acceptable to leave a properly fitted non leaking bayonet in as a point of disconnection, (without testing how will you know) if it is going to be permanent i would suggest the bayonet was plugged, it is a spring loaded valve and could leak
Back to top
 Alert Moderators
John506
from United Kingdom
Thanked: 70 times
PostPosted: Fri Nov 21, 2008 12:36 am Reply with quote
Yes these are very prone to leaking, the main cause of a drop on the manometer on a tightness test when the cooker is out.
I would advise to plug it, though I'm not Corgi registered nor have gas qualifications (yet) so my knowledge isn't great.
Don't forget to use gas paste if screwing a stop end into it.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Removal of Shower Drain Trap 3 460 Fri Feb 01, 2008 7:07 pm
3-PORT MID POSITION VALVE REMOVAL/REPLACEMENT PROCEDURE .... 5 1420 Thu Feb 28, 2008 2:04 pm
Removal of a Tempus 7 6 280 Sat Jan 26, 2008 11:35 am
Baxi Bermuda 552 removal 2 280 Thu Jan 24, 2008 11:38 pm
Rad removal 4 340 Sun Jan 20, 2008 12:35 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
