Draining washer to rainwater drain in Derbyshire
24 Oct 2006
I've been searching and found lots of different advice which I've not really been able to get a definitive answer from. Basically I have an extension on the front of the house which is being made into a laundry room downstairs and a bathroom upstairs (bath only, no toilet or sink).
At the opposite side of the house is the waste stack. Now I could at a push run the bath waste right round the outside of the house with enough of a fall to drain but it wouldn't look good. The washer though is at ground level and there's no way to get the waste round to the stack. My query is can I connect either/both washer and bath to a drain which currently just has a gutter feeding it? The house is in Chesterfield, Derbyshire. Have triued building control but keep getting told there's nobody free and to try later.
Can anyone advise please?
Now that's the problem. We just bought the house and the previous owners built decking over the manhole, and under the decking is a big double glazed window unit. To get at the manhole I'll have to remove the decking in quite a large area to get the window out. Just wondering if anyone local in the area knew the answer or would building control know if I asked.
Was hoping not to get to the point of costly bills to get them out doing all sorts of inspections, but also don't want to get it wrong either.
Sorted with a big thankyou to Chesterfield Council, particularly Building Control. Called back when they said they would and very helpfull.
Turns out that where I live rainwater soakaways are not allowed and haven't been since many years before my property was built due to local mining. All rainwater from all properties drains into sewers along with dirty water and they have no issue with me draining my washer and bath into the rainwater drain as the regs required them to drain to sewers when property was built.
