I've recently fit a Vaillant 838 with VRC430 weather compensator and after speaking to Vaillant had been informed that the efficiency could be improved 5% with this device. When the controller is in the boiler it is not a room stat but becomes one when placed remotely of the boiler by means of 2 core wire (their BUS system).
In order to comply to new energy efficiency standards the room stat must be in an area with a rad with lockshields in order to provide boiler interlock. This is obviously not going to happen when the controller is placed in the boiler. Now I have had a corgi inspector advising me that the installation with the controller in the boiler would count as a discrepancy due to the fact that there is no interlock provided whilst I have Vaillant telling me that the weather compensator provides even greater effiency and feel that their new device is acceptable for efficiency standards. Incidentally they are going to check and get back to me.
I must admit to being a new engineer and a bit wet behind the ears on issues such as these so is anyone able to confirm whether a compensator installed within the boiler, hence effectively a system with no room stat, is sufficient or would I have to remotely locate it elsewhere.
