baxi dhw water problem
28 Apr 2008
can anyone help got a baxi 105 e with exessive dhw temp gets that hot boiler trips out. anybody got any ideas whats wrong?
Could be several things. Try to explain more precisely when and how this happens.
Do the radiators get extra hot since this fault has occured?
no, just dhw temp high,central heating working fine. i've been told its the thermostat
Does the water coming out the tap stay excessively hot till it trips or does it go hot and cold
nobodys messed with gas valve.hot water stays hot until it trips out
Possible Hot water sensor fault just by the plate heat exchanger
