Vaillant combi, Honeywell CM927, Hot water issue
25 Nov 2008
Cambridgeshire
Hi All
I have recently installed a Honeywell CM927 to control my Vaillant Combi boiler. Few hours later my wife screamed from the bathroom as no hot water in the shower. After switching off & on the boiler, later on everything worked fine. A couple of days later, the same thing happened. No hot water and the boiler was playing silly. The boss (wife) did not want anything to do with controller. When I called a plumber he said this could be due to air in the radiators. I had to disconnect the controller until I understand what causes the hot water to switch off.
Is the problem caused by the boiler or the controller? and how to troubleshoot?
Bashir :oops:
Your cm 927 controler do,es not control the hot water side of your boiler.
we require more detail of the boiler ie; which model you have, to give any sort of diagnoes
Hi Bob
Oh sorry, the model is 828E.
One more detail I noticed is that the pressure keeps going down closer to 1, after a day or two and not sure why. Could this cause this problem?
Many thanks
Rgrds
Bashir
