DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Is the system fully pumped or gravity?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
rich1608
from United Kingdom
PostPosted: Fri Nov 28, 2008 4:20 pm Reply with quote
I need to upgrade the programmer on a heating system to give 7-day programming. The current programmer is a Potterton EP2002 24-hour unit and I am looking at fitting the EP6002 which gives 7-day programming with independent hot water and heating switching but this is only suitable for fully pumped systems. My question is do I have a fully pumped system?
The boiler is downstairs and has only two water pipes. The hot water tank and pump are upstairs and the cold water tank and expansion tank are in the loft. There is a Honeywell V4073A1039 3-port mid position diverter valve immediately after the pump with one outlet feeding the heating coil in the hot water tank and the other going to the radiators. The existing programmer has a switch on the back giving the choice of gravity or fully pumped system, it is set to fully pumped. I have spoken to several people who asked where the water tanks were and they said it is a gravity system but I think it's fully pumped, am I right? At the moment the CH and HW work independently or together depending on what is selected on the programmer. Many thanks.
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1242 times
PostPosted: Fri Nov 28, 2008 4:23 pm Reply with quote
its open vented fully pumped.
Back to top
 Alert Moderators
rich1608
from United Kingdom
PostPosted: Fri Nov 28, 2008 4:25 pm Reply with quote
Many thanks for your very quick reply, now I can order the 6002 programmer icon_biggrin.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
HOW DO i CONVERT A GRAVITY HOT WATER SYSTEM TO FULLY PUMPED? 6 1080 Mon Oct 05, 2009 6:49 pm
Help needed is this a fully pumped system or gravity fed 10 180 Wed Jul 11, 2012 2:50 pm
Errr....do I have gravity fed or fully pumped system?? 14 920 Thu Nov 28, 2013 11:16 am
Converting Gravity HW System To Fully Pumped 6 120 Wed Nov 13, 2013 6:42 pm
Gravity System To Fully Pumped 6 160 Sun Feb 17, 2013 3:02 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
