DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Sagging Leather Sofa
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Author Message
Bon
from United Kingdom
Thanked: 10 times
PostPosted: Sat Nov 29, 2008 11:17 pm Reply with quote
Hi all,
Our 2 year old leather sofa has started to sag quite badly on the side that both of us choose to sit on first. It's a leather sofa with fixed foam cushions.
Just wondering if anyone has suffered a similar problem and (even better) if anyone can suggest a remedy or even if people exist who can fix it!!
Living with it is not an option I'm afraid as it's causing distress to a certain member of our household (and it aint me!) and what with all these sofa ads on the TV at the moment I fear for our bank account!!
Back to top
 Alert Moderators
Symptoms
from United Kingdom
Thanked: 50 times
PostPosted: Sun Nov 30, 2008 2:22 pm Reply with quote
Bon - assuming the pair of you aren't big fat lumps icon_lol.gif then the fix may mean un-tacking the dust cover under the sofa (tip the sofa on it back to gain access) and check the condition of the cushion supports. These'll be sprung wire (piano wire with a spring at one end attached to the frame at the back and front), or just wires, or webbing belt, or rubber strap (this stuffs got a special name but I can't remember what it is - others may know), or on really cheapo furniture a sheet of chipboard (or ply if you're lucky). All of these systems are repairable ... new wires, or re-tension the webbing, or slip in a new chipboard/ply deck (or brace the old one).
Spare parts for repairing are readily available from any upholstery supplier ... check your local Yellow Pages.
Back to top
 Alert Moderators
Bon
from United Kingdom
Thanked: 10 times
PostPosted: Sun Nov 30, 2008 6:32 pm Reply with quote
Whilst I admit I may not be at my, ahem, fighting weight, the wife certainly isn't a "lump"
It seems to be more the foam that isn't returning to its original shape than the actual support so I was thinking more along the lines of replacing that (the method of access will be the same as you suggest I would imagine though).
Thanks for the advice though, I'll get onto yell.com right away.
Back to top
 Alert Moderators
bob-the-builder
from United Kingdom
Thanked: 2 times
PostPosted: Mon Dec 01, 2008 9:01 am Reply with quote
Last edited by bob-the-builder on Fri Sep 28, 2012 11:24 am, edited 1 time in total
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Mon Dec 01, 2008 10:05 am Reply with quote
Had a similar problem with a fairly expensive leather sofa a few years ago; it was still under warranty so they sent an upholsterer around. He said it was due to cheap foam inserts which just donít last; seems price doesn't necessarily guarantee quality! The new ones he fitted were noticeably firmer but they are still good 5 years later.
Back to top
 Alert Moderators
Bon
from United Kingdom
Thanked: 10 times
PostPosted: Mon Dec 01, 2008 12:40 pm Reply with quote
Thanks Bob. Unfortunately our cushions are past repair as adopting your method results in them returning to their sagged shape. We will however be doing as you say with the new ones! I agree with you and don't mind the sagging as it's more comfortable, it's just that we have 2 sofas and the other is hardly used so they look a bit odd!
Cheers too Richard, ours weren't at the top end of the price range (they weren't cheap though) and from John Peters. I'll look into getting them re-upholstered and let you guys know.
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 226 times
PostPosted: Sun Dec 07, 2008 5:49 pm Reply with quote
We also had a guy round to re-stuff our leather sofas. All he did was tip it up, and stuff extra foam above the belts, extra padding.
Think with fixed cushions, any other type of support is a bad idea - I expect sprung bases cant be re-stuffed very easily!!!
Back to top
 Alert Moderators
RoachForLife
from United States of America
PostPosted: Mon Jan 25, 2010 3:27 am Reply with quote
Sorry for reviving an old post but I just bought some used couches and one of them was way saggy on the middle cushion. I took off the dust cover and saw that there are many belts (lots front to back) and 2 side to side. One of these was ripped apart, also the wood supports were all broken.
So Im looking to repair. I guess my question is, is there a photo of what it SHOULD look like under there? I can guess and it will probably be close but Im not sure what they typically look like. Maybe I could beef it up somehow too. Like additional wood beams or more belts or the like??
Also are replacing the belts a pain? I was thinking of reusing the existing if I could and find a way to reattach the two ends, like with a crapload of staples or similar.
Thanks all!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Sagging sofa - tried guides? 11 200 Mon Jul 28, 2014 1:16 pm
Leather sofa 3 860 Thu Nov 05, 2009 3:00 pm
Leather sofa (furniture) treatment 4 3540 Wed Aug 27, 2008 9:26 pm
Hair Dye on a Cream Leather Sofa 4 32460 Thu Dec 05, 2002 7:24 pm
Help with damaged leather furniture? 2 1420 Mon Jul 31, 2006 4:12 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
