Can anyone help?? When I switch the washing machine on all lights flash for around 10secs and then the machine goes back to normal. The machine seems to be ok after this and goes through a full cycle. Any one know what this fault code means and how to fix it?
The washing machine does sit above the area where the pipes come through. It also has been cold here of late. It will be interesting to see if it disappears when the temperature rises. Thanks for your help.
