Hanging a heavy mirror- 30.5kg onto a plasterboard wall????
2 Dec 2008
I have recently bought a mirror that weighs 30.5kgs. I bought it to go onto a plasterboard wall of my new build apartment and now have doubts on how to actually put it up securely!!
I have managed to find a beam that runs down the middle of the wall but I am afraid that if this is not going to make it secure enough then it will fall down... and the weight of it will not only break the mirror, it will do a good job at ruining my laminate flooring aswell!!
If anyone has any ideas please let me know.... :confused:
you'll be surprised how much a plasterboard wall will hold, a mirror doesn't project outwards and therefore has very little 'lever' effect, the force is transmitted downwards. If you can, screw into existing wooden studs, if not try expanding rawl bolts. Ikea mirrors tend to be very heavy, I hung one on a plasterboard wall using self tapping metal rawl plugs. No problem at all.
Matt
No problem at all.
....................untill it fell down :LOL:
and there was me thinking people were polite on here!? i'm assuming because a smiley was added that means its ok to be rude? tut tut,
just because somebody doesn't have 20000 posts doesn't mean their advice is invalid, just means they have better things to do than constantly post on forums.
thank you to all those who have helped so far :)
i put the lauging smiley there because i thought the way it is written is amusing
hmm ok 'breezer', was a bit moody yesterday, bad day at work, sorry for snapping :)
Matt
Matt
hi, not too good at using this forum.... im new!! thanks for that, we bought some screws that expland once in the plasterboard for heavy objects, so im hoping that they will work....
Matt
ahh, there you go.... ive jsut realised how to quote!!
There are a few different ways to tell if its a timber framed building. The walls will sound hollow, but will usually sound solid over the frames because of the timber lintels, whereas dry lining will still be hollow there. If you look in the roof space you can tell by the gable walls.
Timber frames will usually have weepholes at DPC level, while masonry usually don't.
If you have got a timber framed house it would be better to fix the mirror to the studwork if possible.
I agree with Ridwood. Use metal plasterboard plugs. Once they're in, they are solid. I've hung many heavy objects using them. If you've never used them before though, you only get one chance, or you'll be left with a gaping hole to fill. And don't over tighten. When they nip tight, leave it.
Anyhow, there's me going on a bit. If you have a timber stud where you want to hang the mirror, use that!
