DIYnot
Local | Network
   DIYnot > Forums
Local | Network
glow worm boiler ignition problems
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
cris56
from United Kingdom
PostPosted: Thu Dec 04, 2008 10:39 am Reply with quote
We have had problems with ignition. various gas techs have been called in and have appeared to fix the problem or have gone away to refer to glow worm for advice never to return to us. Latest gas man has decided it could be a blocked jet, tiny apparently, smaller than a pin head. Also, the ignition wire was broken although, a spark is clearly visible and intermittently the boiler will light and run, however, when it cuts out it will often take a long time before it will finally ignite. It is an intermittent problem but last night, coldest night of the year, it failed to light or stay a alight at all.
We are now considering a new boiler, we are currently waiting for the gas man to bring round new jet and ignition wire thing, please note accurate technical terminology. Last ditch in desperation as my husband is not convinced that a blocked jet could cause this problem intermittently and he has lost all faith in 'gas men'.
To clarify, ignition sequence will often run for a minimum of 10 15 mins before ignition is achieved and less often, 3 sparks and it will light. Any advice would be most gratefully accepted
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
glow worm Flexicom 12hx - ignition problems 13 5200 Tue Oct 30, 2012 4:31 pm
Glow Worm Flexicom HX pops on ignition - common fault? 19 2140 Sat Aug 15, 2009 7:07 am
Glow worm Ultimate 40FF not starting Ignition sequence 2 640 Mon Mar 17, 2008 1:02 pm
Glow Worm Micron 50FF Ignition Problem 2 40 Sat Feb 04, 2012 11:05 am
glow worm ultimate 30ff ignition problem 9 340 Fri Nov 05, 2010 5:34 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
