DIYnot
Local | Network
   DIYnot > Forums
Local | Network
extension lead problem
Author Message
Srodders
from British Virgin Islands
Thanked: 1 time
PostPosted: Sun Dec 07, 2008 7:32 pm Reply with quote
Have a reciprocating saw which i wanted to use at the bottom of the garden to cut up some logs. The saw works fine when plugged in the house, The extension cable I have to use to reach the bottom of the garden (one desigend for use outside) works fine on all other electrical equipment (shredder, blowervac etc) however the saw just won't work on the extension. It doesn't trip the RCD or blow a fuse or cut out - it just doesn't work.
Any ideas why not - and what I could try to get it working on the extension?
Thanks.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Sun Dec 07, 2008 7:56 pm Reply with quote
a picture / info would help, other wise, no idea
Back to top
 Alert Moderators
Srodders
Thanked: 1 time
PostPosted: Sun Dec 07, 2008 8:02 pm Reply with quote
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 1084 times
PostPosted: Sun Dec 07, 2008 8:06 pm Reply with quote
Sounds like an issue with volts drop.
Your saw will take quite a bit of power initially to start it turning.
This will possibly make the voltage drop too low to start the saw due to the additional resistance of the long extention lead.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Strange extension lead and powered USB hub problem 2 220 Fri Dec 21, 2012 1:02 am
Arctic cable for extension lead 19 820 Mon Mar 17, 2014 2:27 pm
coil extension lead 5 820 Thu Jul 28, 2005 11:56 am
cable for extension lead 18 320 Wed Apr 24, 2013 6:50 pm
Plug-in RCD on extension lead? 18 300 Tue Nov 18, 2014 7:25 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
