DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Failed capacitor on Grundfos pump?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Odyssy
from United Kingdom
PostPosted: Wed Nov 03, 2004 9:49 am Reply with quote
Conventional vented system, the pump isn't running. I've removed the vent plug and cleaned the debris out - shaft was turning freely. There is power at the pump and I've tried tapping it with a hammer.
The only other possibility other than replacing the pump, is that the capacitor has died. The system has been noisy on start up occasionally over the last couple of weeks with hammering and boiling over into the header tank, although the pump usually started. The pump is a grundfos UPS 50-15x18. Any thoughts gratefully received. Thanks
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1097 times
PostPosted: Wed Nov 03, 2004 1:26 pm Reply with quote
Measure the resistance of the windings, L - N, which shouldn't be zero or infinite. A 5 multimeter would do it.
Cos I'm a smartarse I'd measure the capacitance of the capacitor icon_cool.gif
They do fail, but yours is quite an old pump so probably worn anyway. Wilo's are bad for blowing capacitors, Grundfos not so often.
Back to top
 Alert Moderators
Odyssy
from United Kingdom
PostPosted: Wed Nov 03, 2004 3:27 pm Reply with quote
Chris - thanks, you were right - capacitor dead. I've replaced the pump anyway and the improvement is quite amazing - the whole system is much quieter, the old pump must have really been on it's last legs. I don't think I even need to replace the boiler - no kettling! Yippee!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Pump Capacitor 16 440 Fri Feb 11, 2011 7:23 pm
Stuart Turner Showermate shower pump start capacitor 2 40 Thu Sep 06, 2012 7:15 pm
Pump capacitor causes earth fault 9 200 Fri May 17, 2013 8:55 am
pump motor capacitor - where can i get one? 14 960 Sat Nov 21, 2009 12:46 pm
Pump or just capacitor? 46 1540 Sun Apr 28, 2013 10:38 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
