Device to stop French door from swinging in wind?
9 Aug 2006
Lancashire
We have had bifold alu doors fitted at the back where it gets very windy. In summer when the doors are open, the access door will be free to swing open and will not stop until the frame hits the reveal. This will damage the frame and could even damage the hinges by leverage.
We need something, which will stop the swinging door then capture it. I have searched through all the online door furniture catalogues without success so I am thinking of knocking up a bracket, which will be screwed to the reveal and braced to the wall outside, incorporating both a buffer and a clip to hold the door in place.
I could sink a post into the ground and use a hook but I am certain that either Grandma or our absent-minded son will one day forget to hook the door, which will fly open and self-destruct. Only one violent swing will be enough to damage the frame.
Anybody got any suggestions for a ready-made solution or home-made?
you can get a self-latching door stop/catch, but I don't know what they are called. Might be a sort of Door Holder.
Has a sloping flat brass plate on a spring, when the door first hits it, it slides up the slope and the plate pushes down on the spring, then as the door passes the plate, it springs back up and prevents the door swinging back. You press on the plate when you want to release the door.
"Ironmongery Direct" probably have them.
Or you could use a counter catch or a magnetic door holder
Or maybe
Thumbnail.aspx
Ive fitted 5" satin chrome on brass cabin hooks; B&Q sell them.
JohnD's suggestion is a 'bar catch or hook' or a 'counter flap catch'.
I don't know what it's called, but you can/could get a thingy a bit like a single armed door closer. When you open the door, at a certain angle (depending on where you fix the bracket, the arm catches and locks itself, and the door will neither open or close any more. There is a hanging string which when pulled, lifts the catch and allows you to close the door. (Might be what JohnD is talking about, but I think he's describing something that goes at the bottom of the door - this thing goes at the top).
If this is of interest I'll dig the bits out and photograph them. It used to be on our garage doors.
It's not however the sort of thing you'd probably want to see fixed to the inside of your posh patio door though - a bit "agricultural" if you know what I mean.
I think I know what you mean. The problem is that lots of classic control devices won't fit because they're designed for wooden doors whereas these have a complex profile with all kinds of rubber seals.
