Double Glazing - Handle broken and window does not close
10 Dec 2008
Antrim
Hi, I need some help and advice. In my flat I have two main windows in my living room. These windows are double glazed and are the type that open two different ways (from the handle closed pointing down, (1) turning 90 degrees hinges them from the bottom and (2) closing and turning a further 90 degrees pointing the handle up makes them hinge from the side like a normal window.). When you closed the windows, the handles never fully turned vertical pointing down, but close enough.
My problem is the other night I was closing the window and heard a crack and the handle went fully vertical. Now, the window is permanently stuck in position (1) hinging from the bottom. Turning the handle 90 degrees does nothing and feels limp and it cannot be pushed any further, even if i push the window closed and try to move it up. Does anyone have any ideas what could've happened and how this can be fixed? I have read that it could be a spring in the handle. The handle unscrews from the back. Any help would be very much appreciated.
