I've recently noticed a hairline crack running vertically through the grout in my shower, from the top to the bottom of a stud wall, which I think just has plasterboard behind it.
As all the work was done before I moved in I don't know if the grout is decent, whether the stud wall is WBP Ply/Plasterboard/Wediboard or similar and I also have no idea whether it is tanked.
To fix this should I remove all the grout down the vertical gap and some from the intersecting horizontal ones then re-grout using a decent grout or am I just saving up problems for the future? Keen not to spend too much money/time on this at the moment but if I need to do a more extensive fix to prevent problems in the short term then I will.
Thanks in advance,
e_v
Thanks in advance,
e_v
