dan - they're normally made from fireclay (a refractory material) not concrete; concrete tends to splatter (explode) when subjected to DIRECT heat. Just the same as you can get firebricks - ordinary bricks will splatter.
My old man used to call them "Chairs". he used to sweep chimney's on the quiet. Odd I should remember that........ Noseall's post gave me a physco-prod.
It is indeed the 'fireback' I am trying to describe. Do they come in different sizes?
Also I may need to change the lintel and a few bricks for cosmetic purposes. Bricks have to be fire-bricks? And the lintel? I've been searching the net and I've seen and steel 90 degree angle lintel. Is this the one to use??
dan - firebricks are only used if subjected to DIRECT heat/naked fire, say a hearth or forge lining. You don't need them to repair chimney breasts. Take photos of the old fireback before you smash it so you can then easily ID a new one. Loads of websites that do replacement stuff.
Dan- There are different sizes of fireback. You could buy the throat lintel from the same place to match it. The firebacks usually come in 2 pieces. If they are in one piece they should have a score mark where you need to cut it. This is because the bottom will be hotter than the top and expands at a different rate.
The most common cause of the fireback cracking is the brick rubble infill at the back settling over a period of time and expanding when hot and putting pressure on the fireback.
Alternatively you could build a fireback from fire bricks bedded with fire clay.
