Monument Tools - Expansion Vessel pump/valve parts?
5 Oct 2008
Bournemouth
Hi again
Is the Schraeder valve and schrader valve pump from Monumnet Tools any good ? I am thinking it is a good item (s) to have for when re-pressurising an expansion vessel?? Anyone else got these ??
what about the schraeder valve fitting/connector? and what size connector do you use?
Footpump, straight on the valve.
But if it has lost air, putting it back it will normally only be a temporary fix. Expect a call from your customer expecting a gratis return visit.
For this reason, we suggest changing them when a significant pressure loss has occurred, or you will go out of business servicing all the free callbacks.
Don't rely on the pump gauge for the pressure, it can be miles out.
I use this
Accurate, and the price is not bad.
If it has lost air the most common cause is a faulty schraeder valve. I keep a stock of these in the van. Halfrauds or any motor factors keep them in stock. It's easy to check, after repressurising a quick squirt of leako round the valve soon highlights any problems. The only time I've ever had to change vessels is if the diaphragm has gone or the vessel has rotted through.
If there's any doubt just tell the customer that there may be an underlying problem that is not immediately evident and this will cost a lot more to rectify. Most customers will be willing to take the risk rather than spending out on an unnecessary expansion vessel.
Mike
P.S. to check pressures I use a small digital pressure gauge.
Analogue ones have infinite resolution, and the button on the side releases air if you need to drop the pressure. It is more reliable in my experience than digital types.
Fair point but the setting of expansion vessel pressures has never been that a precise science. If it's good enough for my tyre pressures then I am happy to use it for expansion vessels. I do like the idea of releasing the pressure though. Mind you I mainly install nowdays rather than maintenance so I'll not worry too much for the odd time when I need to drop the pressure.
Mike
