- Joined
- 27 Jan 2008
- Messages
- 28,792
- Reaction score
- 3,513
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
When taking power from an isolation transformer how does one protect? It is unlikely any 3 KVA transformer will give the 2.875 ohm impedance required to trip a MCB on the magnetic trip and whole transformer only feed from a 16A MCB in first place with volt drop being a likely problem not sure if active rather than passive RCD should be used. But I can see no point in using duel pole RCD except I don’t think one can buy single pole. All lighting comes from the inverter so it will only feed sockets so I think just a single duel pole RCD is all that is required?
Second question is in-rush an active RCD would ensure it is connected with no load but a 3 or 4KVA transformer may still trip a B16 MCB although one would hope marinas would used D16 but with a B16 can some simple soft start be used like a resistor which a few seconds after connection is shorted out like used with resistor start motors has anyone seen this done? Also losses is there a standard marking so one can tell how much off load current the transformer is going to draw before buying it? I know with 110 volt transformers the losses with a wall mounted transformer in a tin box are a lot less than those with the type fitted into a yellow plastic box with handle and I expect the same with isolation transformers. Price also seems high as a 3KVA 110 volt transformer is priced at around £54 but the isolation transformers seem to start a £200 for type in plastic case to £275 for type in tin box. Does anyone know where I can get cheaper options?
Eric
Eric
