DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Potterton Boiler pressure valve leaking water
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
BunnyBoiler1
from Ireland
PostPosted: Wed Dec 17, 2008 7:50 pm Reply with quote
Hi - Pressure on combi boiler from sealed system keeps dropping to 0.5bar which means i keep having to open the valve to get it working. When i increase pressure at only one bar the pressure valve of the boiler starts releasing water. What is the likely problem ? This has never happen before - normally i would have to increase the pressure significantly for the pressure valve to release water.
THanks
D.
Back to top
 Alert Moderators
swbjackson
from United Kingdom
Thanked: 148 times
PostPosted: Wed Dec 17, 2008 8:45 pm Reply with quote
I would suspect that the pressure gauge itself is faulty.
Mike
Back to top
 Alert Moderators
gavinda
from United Kingdom
Thanked: 26 times
PostPosted: Wed Dec 17, 2008 10:39 pm Reply with quote
or the prv is just passing and the increase pressure makes it do this more. why not rrelease all prssure cleane the prv valve seat and check the pressure vessel is fully charged.
Back to top
 Alert Moderators
BunnyBoiler1
from Ireland
PostPosted: Fri Dec 19, 2008 2:01 pm Reply with quote
Cheers Guys - Really appreciate your help.
So if the prv is just passing - i would be supprised due to only 1-1.5 bar of pressure. I would have thought it would take more before it would pass.
So how do i release all pressure from this potterton puma and how do i clean the prv valve seat ? Is this something a lay person icon_redface.gif can do or should I call in specialist help
Thanks again and Happy Xmas to you both
Back to top
 Alert Moderators
jackthom
from United Kingdom
Thanked: 120 times
PostPosted: Fri Dec 19, 2008 2:28 pm Reply with quote
You're not the only one with PRV problems there's a bit in the FAQs about them. http://www.diynot.com/forums/viewtopic.php?p=308252#308252
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Potterton performer 24 leaking differential pressure valve 4 1120 Thu Aug 23, 2007 1:30 pm
Potterton 100 Boiler - Low Pressure Light & leaking 6 60 Tue Nov 29, 2011 9:09 am
Potterton Performa 28 - Leaking Diverter Valve Front Section 14 4140 Wed Jul 22, 2009 9:44 am
Pressure valve AND automatic air vent leaking water 4 2080 Mon Feb 23, 2004 4:21 pm
Closed Leaking Rad valve, But Boiler Still Losing Pressure. 2 60 Sun Feb 23, 2014 9:25 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
