DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
PVC Window lock problem
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
  View previous topic :: View next topic
Author Message
McLovin28
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 22, 2008 3:58 pm    Post Subject:
Reply with quote Thanks
I'm having a couple of problems with my windows that I would like help with, I must say that I have no experience with windows but I'm pretty good at general diy.
1. I have a cracked window that I would like to replace but I'm not sure how I would remove and replace the beading.
2. How do I measure for a new window as I know a place that makes them and when I gave rough calculations it was only going to cost me £30 and for a company to replace the window it was going to cost me £200!!!!!
[IMG]http://i284.photobucket.com/albums/ll39/28kennedy/Window002.jpg[/IMG
3. Another window I have seems to have a broken lock, it wont open, when I open the handle, it seems like the bolt unlocks on the right side but it is still locked on the left side. When I remove the handle to look at it the locking mechanism inside the window (second picture below) moves about freely (not sure if this is supposed to be like that). So how do I get the window open? I'm not bothered if it doesn't lock again aslong as it opens and closes as its the toilet window!!!!
These pictures are pictures of the lock on a different window which I assume will be the same
When the handle moves down two bolts come from the end of the frame and also a bolt goes down just underneath the handle
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
xerxes
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 22, 2008 5:26 pm    Post Subject:
1. To remove the existing beading, you need one or two scrapers or similar tools: I find well-worn putty knives work quite well. Start to prise out a bead from one end; insert a second tool if you need to hold the gap open to get some more leverage.
But search this section for more advice (the topic's been covered before). For example, for some types of glazing you need to remove the gasket first. It's a good idea to mark the beading before you remove it, just in case the opposite pieces aren't exactly the same size.
2. You ask how to measure for a new window. If you mean, how do you measure the glazing unit, you, er, use a tape measure or something similar. Measure the thickness too, so that you can order the correct replacement. Note the colour of the spacer (usually silver) to order a matching colour. Also, note the position of the existing packers so that you can put them back in the same places.
If you meant to ask how to measure the whole window, measure from brick to brick in three places horizontally and vertically; take the smallest of each of the two sets of measurements and deduct 10mm clearance to give the size of the window.
3. Difficult to say what the problem is with the stuck window, but it's possible that the opener is slightly distorted. Check to see if the mitres of the opener align with the the mitres of the outside frame; if they don't, you could remove the glazing unit and repack it to make the window open and close properly.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
UPVC front door lock problem :s 6 820 Mon Jan 22, 2007 9:29 am
upvc Door lock problem 5 720 Sun Apr 29, 2007 9:21 pm
upvc door lock problem 8 520 Wed Aug 27, 2008 3:17 pm
UPVC exterior dorr lock problem 9 760 Wed Aug 01, 2007 11:32 am
upvc porch door lock problem 6 680 Tue Mar 07, 2006 10:12 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
