How do I take this patio door lock off?
28 Nov 2008
Buckinghamshire
Included a photo to explain my problem in more detail.
So its not a phillips or straight head type of screw head, how do i take it off? I need to replace it with a new lock.
drill the head off
if you can get some left handed drills (sold for this purpose) the torque and vibration will often undo the screw.
if not, once the head is off, the lock will come off and you can use a mole to grip and turn the shaft.
You need to clean the slot head very carefully to see what type of screw head it is. Clean it out with the needle of a compass or something similar
I was expecting it to be a clutch-head one way screw.
Cant drill anything off. Im gussing when it was originally installed it came with those screws and a special key/ellen key? to put them on. I dont have anything original.
I just need to get it off so I can put a new one on.
Note the description "CLUTCH HEAD SECURITY SCREWS
VANDAL RESISTANT - 1 WAY - PERMANENT SECURITY SCREWS"
they are designed so you can't undo them with a screwdriver. This is to prevent burglars or others taking your locks off. Sometimes a slotted driver if you press very hard will grip enough.
Otherwise drill it.
They cant all be one way screws, ive read some descriptions which just says turn anti clock wise to take it out.
When you say drill it, do you mean get a power drill with a thin bit on the end and just drill into the head so it breaks?>
yes they can
You want a drill which is about the same size as the shank of the screw, then it will not do any harm if you penetrate into the door frame.
If you use a fine drill it may well break.
