Is Plaster easy to saw?
30 Jan 2008
Gloucestershire
This isn't a building question! - I am hoping to make a sculpture using mostly plaster, I then want to slice the sculpture into several cross-sectional pieces. Is it fairly easy to saw thin (half inch) plaster without it fraying or splitting badly, and would it leave the saw in a poor state afterwards?
cheers
douglas
regular skimming i.e. thistle multi and board finish will be rather brittle.
i would be inclined to use something more dense like dry wall adhesive.
unless you cut it with a fine wet saw then any plaster product is likely to splinter and also ruin the saw.
Ive used a jigsaw on plasterboard (fireboard) and it was like a hot knife through butter :D
Yes, but remove the paper backing and it will crumble like a knife through some Wensleydale cheese
Thanks for your replies chaps.
I probably will chose to use plaster of paris, does anyone know whether that will respond any differently from ordinary plaster and be difficult to cut?
cheers
douglas
i always thought P of P was moulded into the required shape then left to set, since its made up thinner than custard
does it have to be plaster? what about a tin of expanding foam? line a box with polythene, spray in foam, leave for at least 48 hours remove box and you can shave the foam with a surform, or cut big bits with a bread knife
does it have to be plaster? what about a tin of expanding foam? line a box with polythene, spray in foam, leave for at least 48 hours remove box and you can shave the foam with a surform, or cut big bits with a bread knife[/quote]
Very interesting could just be what I'm looking for, thanks breezer, I'll certainly give this a go!
cheers
douglas
