DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Ferroli 901 fan relay not working?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
MikeyGuin
from United Kingdom
PostPosted: Sun Dec 28, 2008 6:51 pm Reply with quote
Hi Guys,
This is my first post so I hope you can help?
For my sins we have a 901 and the fan relay keeps sticking, and after 30 seconds of a loud "BUZZING" only then will the fan start up.
Does anybody know if
A) The relay can be pulled out of the PCB or is it soldered in?
B) Can the relay be sold seperate or do you need a new PCB?
C) Can the relay be "cleaned" out?
Many Thanks
Mike
Back to top
 Alert Moderators
weargas
from United Kingdom
Thanked: 14 times
PostPosted: Sun Dec 28, 2008 7:06 pm Reply with quote
(A) It is soldered in but I'm sure someone with microelectronics (if you can find someone) experience can source and fit a relay.
(B) They won't sell a relay seperately, they make you buy the whole PCB and they've just gone up in price.
(C) You can clean the contacts on the relay You'll have to break the clips on the plastic cover to get it off but you may find that the plastic arm that moves the contact has melted because of the sparking (if it's been doing this a while) and the arm no longer switches properly anyway.
Back to top
 Alert Moderators
MikeyGuin
from United Kingdom
PostPosted: Sun Dec 28, 2008 7:21 pm Reply with quote
Thanks weargas, its seems from your reply this is quite common.
I will try and clean out the contacts as the buzzing noise has only been going since yesterday, if all else fails I guess a new PCB icon_sad.gif
Back to top
 Alert Moderators
MikeyGuin
from United Kingdom
PostPosted: Sun Dec 28, 2008 9:10 pm Reply with quote
Tried cleaning the contacts, no good they were too corroded, how much do u think a new PCB board is?
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 64 times
PostPosted: Sun Dec 28, 2008 9:53 pm Reply with quote
Last one I got was about 250 quid.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3558 times
PostPosted: Mon Dec 29, 2008 12:42 pm Reply with quote
The relay is a standard component and probably available from Maplins or failing that RS Components.
However, if its buzzing then that implies that its being supplied with raw DC rather than smoothed DC and there may well be another fault than the relay itself.
Your boiler is getting quite old and is overdue for replacement. This may be the time to replace it !
Tony
Back to top
 Alert Moderators
diy
from United Kingdom
Thanked: 1 time
PostPosted: Mon Dec 29, 2008 1:11 pm Reply with quote
Back to top
 Alert Moderators
MikeyGuin
from United Kingdom
PostPosted: Mon Dec 29, 2008 2:13 pm Reply with quote
Thanks for all you help guys, Tried maplins and they dont supply that particular relay, Then went to my local Plumbase 150 all in for a new PCB, all fitted and working as new icon_biggrin.gif
Heat at last!!
Back to top
 Alert Moderators
weargas
from United Kingdom
Thanked: 14 times
PostPosted: Mon Dec 29, 2008 7:48 pm Reply with quote
I absolutely love people who post a "closure" post. Glad you're up and running mikey.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Ferroli Optima Honeywell VMF7 PCB Relay Fault 8 620 Sat Mar 27, 2010 7:01 pm
No fan, pump working. How to test fan relay? 6 280 Mon Dec 06, 2010 5:37 pm
HC60NG relay box, not working!!!!!!!!!!!!!!! 9 980 Wed Nov 12, 2008 8:26 pm
Powermax 155x advice please - Vent and Pump Relay faults? 12 940 Fri Dec 04, 2009 2:09 pm
trianco eurostar relay 7 640 Tue Dec 23, 2008 11:50 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
