Hi thanks for that i have sucked and blowen on the aps pipes still did not fire up or try tochecked the aps
iv ghecked that was not tripped outquickly check that the o heat stat under boiler hasnt tripped first
you could link it out but you can also check switch electrically without power on using multimeter. Check if you are getting continuity between common and normally open when you make switch by sucking and pinching
is the fan running constantly or does it keep stoping and starting
just running constantly
its funny you say that it worked all day now its doing the same thing again. Think the old fan was runing a bit slow as it fired when i sucked on the pipes on the aps. S0 i will fit a new aps next see if that works it also fires up if i pull the clear hose off the aps any ideas.If the old fan ran constantly then a new fan would run constantly too.
Something else much have been done to correct the fault.
Tony
