Nissan Micra. Flat battery can not open door
27 Feb 2007
Aberdeenshire
My neighbour has gone abroad his car needs to be moved, battery has gone flat how do I open the doors there are no door locks, It is an 03 Nissan Micra ??? help please.
I have read that there is a removable plastic cap on the end of each door handle, for use in emergencies. Apparently you prise off the cap carefully and insert the key.
I can't vouch that this information is correct, but it's worth a look.
Otherwise, can you email or text your neighbour and ask if he knows what to do in these circumstances?
I have one - I think that the key entry is only on the passeger side - there is a marker on the handle where you need to remove the plastic cover to get at the keyhole
HTH
I know this was posted a million years ago, but it was the first hit I got from Google.
Yes, it's under the passenger's handle - there's a small key icon on the plastic cover, and a pry hole on the bottom edge.
